I think this is the computer or sensor?
Old May 20, 2005 | 01:45 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Here is my problem. Every so often, maybe 3 times a week, My SES light will come on and my tach shudders for a moment. I can feel the car is lacking power. The SES light will shut off sparatically and the tach shudders again and the engine has full power. When the SES light is on it feels like something is clogged and the engine just cant perform right. Here's the funny part. If I shut my car off when the SES light is on and I restart it, it will stay on until what ever it is causing the problem fixes itself and it will go out. If I shut the car off with the SES light on and do a diagnostic check it only displays code 12. When I turn the key off and start the car again the SES light goes off and the car runs fine again. This problem is more annoying than anything else right now. I have had this problem about 2 months now. I know it is not anything clogged in the exhaust system because I just completed a header install, neew cat, and 3" pipe all the way back. I have good plugs, wires. I replaced the cap, rotor and coil about 6 months ago. Pcv valve is new. AIR pump works. What can be doing this? I appreciate any help.
Tony
Old May 23, 2005 | 02:50 PM
jeramy.reese's Avatar
Car: 85 T/A
Axle/Gears: 3.08
Have you tried doing a diagnostic while the engine is running? If you do this and still get a code 12 then it might be a problem with the distributor reference signal. At least that is what an old Chilton's manual is telling me. I have done this with my own car and not gotten the code 12 while it was running.
Old May 24, 2005 | 06:45 AM
Car: 1986 Iroc-Z
It wont pull a code while it is running. It just keeps the SES light on constant. The ignition module went out last December and I had to replace it. I have also replaced the cap, rotor and coil just for maintenace and tune up purposes.
92firebirdguy
Sep 1, 2016 07:53 AM
sleprock
Oct 1, 2015 09:39 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Eric-86sc
Sep 7, 2015 02:10 PM
