Coolant temp gauge - wacky
Old May 20, 2005 | 02:32 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
My coolant temp gauge never reads correctly. Sometimes it points straight down, sometimes what seems to be correct and then 20 minutes later somewhere else. I replaced tha gauge and the problem is the same. Do you think it is the coolant sending unit that is located on the left side of the engine by the manifold?
Tony
Old May 20, 2005 | 02:53 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
Re: Coolant temp gauge - wacky
Tony
its worth a shot, they arew cheap
Old May 20, 2005 | 09:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I would also check to make sure that the wire for the temp sending unit isn't shorting out in the engine bay.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
L98GTA87
Oct 19, 2015 10:43 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
