help with testing autometer gauge
Old May 20, 2005 | 06:19 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i have purchased a set of autometer electric gauges (covan kit) i had the gauges working fine before i tore the old motor out and went from carb to tpi. now it seems that the oil pressure gauge isnt working. i switched the sender and went with the stock sender for the tpi. if you look at the gauge it stays pegs at 100psi and doesn't do anything. you turn the key on and it doesn't move. i took it out of the car and the needle stays at 100psi. is there any way to test the gauge to see if it still works or did i mess it up. any help would be great. thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
eustodp
Sep 20, 2015 05:09 PM
corey8084
Sep 17, 2015 02:56 PM
90formulaVortec
Sep 8, 2015 12:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
