Power Door Locks aren't locking...
Old May 22, 2005 | 04:34 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Since like, 1996 the locks on my '89 Formula do not lock with the button. They will unlock with the button, but when u hit the lock button they do a half arsed attempt to lock, but they don't. Heres my questions, what is causing this, and what could i do to fix the problem?
thanks, Derek
Old May 22, 2005 | 10:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
A couple of things could be causing this. A weak relay, bent or binding control rods, a weak or dirty solenoid in the door panel. My problem with them was control rods that were dirty and bent slightly.
Old May 22, 2005 | 11:56 PM
Thanks for the info Trickster. If my problem just so happens to be the relay, could you tell me where i could find it?
Old May 23, 2005 | 12:15 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
ON your car you should find it behind the left kick panel below the hood release lever. On most cars it will have a gob of black insulating adhesive stuck over it. It grounds to the car frame on some models.
Old May 23, 2005 | 01:38 AM
great i cant wait to get that crap all over my hands.. lol thanks for the info trickster
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
g.l.mos
Aug 22, 2015 12:02 AM
