hatch pulldown
Old May 29, 2005 | 02:31 AM
rockinfirebird's Avatar
Car: 1988 GTA T/a
hatch pulldown
Yeah, my 88 GTA has a new hatch pulldown motor and tracks but the pulldown still won't work. I was wandering if it was the part in the lid. I sanded the contacts and that didn't help. Please help
Old May 29, 2005 | 03:43 AM
I-Roc with my Z's Avatar
Car: 1989 Iroc_Z
There is nothing in the lid that would prevent it from going down all it is a hook, make sure all connections are working and hooked up properly, the hatch may already be locked, you might need to release the lock.
Old May 29, 2005 | 07:35 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: hatch pulldown
Originally posted by rockinfirebird
I sanded the contacts and that didn't help...
On your car the contact pad and spring-loaded contact pins on the hatch provide power the HMSL (high mount stop light, aka third brake light) when the hatch closes. It has nothing to do with the hatch pull-down unit. Earlier models used that same contact pad to power the rear hatch wiper motor. Did you check for power at the red/white stripe wire that connects to the blue wire? The topic has been covered in depth previously. Do a search and you'll likely find the answer to solving the problem.
Lon
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
punkmaster98
Sep 30, 2015 11:01 AM
formula00ra
Sep 28, 2015 11:50 AM
