wire awg & fuse recommendations
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I have a 2 gauge wire, I was planning to use for my ground to engine, ground to frame and the +12 to the starter, but i've been hearing that you should use 1 awg or bigger for the +12 to starter. Is a 2 awg not good enough?
What gauge wire should I run from the ALT to the battery? Would 10 awg work or should I go bigger?
Also, what size fuse do you recommend for the following objects:
1. Distributor coil
2. Carb choke
3. Elec fan
4. Starter
5. Fuel pump (stock 70 gph)
6. Overall power distribution on the +12 feed
thanks.
1. Distributor coil
2. Carb choke
3. Elec fan
4. Starter
thanks.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
From Alternator to Battery I'd reccomend going as heavy as you can. I changed stock (maybe 12 gauge) to 4. You can't run a wire from ground to frame, ground IS the frame. I think you'd be OK with 2gauge to the starter as well, stock isn't that large so you're already upgrading it. As for the others, I'm not sure.
Car: 88 Camaro
Engine: 310 LG4
if I dont run a cable from the bat to the frame, then how does it get current? none of my components will work.
Car: 86 T/A
Engine: HSR 355
Ghettobird52
Jul 5, 2024 11:18 PM
10, aims, alternator, awg, battery, car, frame, fuse, gauge, recomendations, recommendation, recommendations, siz, size, wire
