prom number
Old Aug 4, 2005 | 11:02 AM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
prom number
i need the number that would be on the prom in an 88 camaro 305 tpi
thanks
Old Aug 4, 2005 | 12:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The code would depend on your rear end ratio but here are your options.
88 5.0-F A/Trans(M39) Fed, 2.73(GU2) 16082173 2174AKFM
88 5.0-F A/Trans(M39) Fed, 3.23(GU5) 16082183 2184AKFP
88 5.0-F A/Trans(M39) Calif, 2.73(GU2) 16082439 2440AKFZ
88 5.0-F A/Trans(M39) Calif, 3.23(GU5) 16082448 2449AKHB
88 5.0-F M/Trans(M39) Fed, 3.08(GU4) 16082388 2389AKFT
88 5.0-F M/Trans(MK6) Fed, 3.45(GM3) 16082422 2423AKFW 6423ANPJ
88 5.0-F M/Trans(M39) Calif, 3.08(GU4) 16082462 2463AKHF
88 5.0-F M/Trans(MK6) Calif, 3.45(GM3) 16082470 2472AKHJ
88 5.7-8 A/Trans(MD8) Fed, 2.77(GH3) 16075399 5400ABYA
88 5.7-8 A/Trans(MD8) Fed, 3.27(GW6) 16083268 3269AKXX
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
