fuel pump
Old Aug 10, 2005 | 08:58 PM
chris91's Avatar
Car: 91 RS Camaro
Transmission: auto
fuel pump
I need help on my 91 tbi camaro . The fuel gauge is max out to the full side and my fuel pump wont run , where do I start looking for the problem ?
Old Aug 10, 2005 | 10:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
the 20 AMP fuse located under the hood near the battery.
Old Aug 11, 2005 | 05:29 PM
chris91's Avatar
Car: 91 RS Camaro
Transmission: auto
fuel pump
I checked the fuse and it is still good , so now what ?
Old Aug 11, 2005 | 08:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is a red wire with a connector in the wire bundle near the fuel pump relay on the driver side firewall. That is the diagnostic test point for the fuel pump. Apply 12 volts (+ side) to that connector and the fuel pump will run if it is good. If it doesn't run you either have a bad fuel pump or a bad wire going to it.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
