headlights
Old Aug 29, 2005 | 04:48 PM
airmanwhite's Avatar
Car: 90 formula
Transmission: 700-r4
headlights
HELP!!!
I just bought a 90 Formula and the headlights wont do squat. Here's what i have done so far. The actual lights do turn on, but i get nothing from the motors. No humming, grinding...nothing. I can move the buckets up and down by hand and the **** on top of the motor does NOT turn. I can turn the **** freely by hand, no resistance, and the buckets dont budge. I disconnected the plugs to the motors and tested for voltage there. While i had someone turn the headlights on and off, no voltage at all across the 2 wires. Next i disconnected weatherpack plugs going into the control module. I have 12v power going into the module on the 5 pin connector but nothing coming out of the male plug side of the module. So is the module bad? i want to be sure cause GM quoted me 208.00 for a new one. And since i live in bo hunk i cant find one used. Im also thinking the motors and bad to cause of the **** on the motors doing nothing. Any ideas. Thank you.
Edit: i tried hotwiring the motor itself straight off the battery with no success. The motor did not do anything. Bad motor assy? Thanks
Old Aug 29, 2005 | 09:18 PM
Car: 90 formula
Anyone? This is my only vehicle and im beating my head against a wall.
Old Aug 29, 2005 | 09:22 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes it sounds as if the headlight control module is bad. I picked up one at the PAP yard, but I haven't had a chance to test it yet. I would start with the module, but I can guarantee that alone won't solve the problem with the headlight motors. You;ll still need to rebuild them with a headlight repair kit such as the TDS p/n 207280 or p/n 209280. The instructions that are included with either kit will also help you repair the motor. Someone may have opened it and failed to re-install the springs behind the brushes.
Lon Salgren
Top-Down Solutions
Old Aug 30, 2005 | 06:09 AM
Car: 90 formula
i was afraid of that. Thank you for your insight into the problem. When i get it fixed ill post back to confirm everything.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
