trying to figure this out..
Old Oct 5, 2005 | 05:19 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i went from an A/C to non A/C heater box in my 92 camaro..
im trying to figure out the connections on that sensor type thing in the main body of the non A/C heater box..
it has 3 connections, and my factory harness had a light grey connector with 4 connection..
which wires do i need.. and which goes to each of the 3 connectors??
i dont know how to read a wiring schematic.. so if someone can tell me based on color code i can do it that way..
Old Oct 6, 2005 | 08:14 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
bumpy bump... need help
Old Oct 10, 2005 | 12:37 AM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
this was a pita when we did this on my freinds t/a. the non ac box only has a 3 speed blower motor, the ac has a 4. but the 4 speed is to long to fit. so, what we did was not use the low speed wire on the stock 4 speed control, and made the other position low med and high. the older motor does not work as good as the 4 speed, so i am going to make a wood spacer so i can install the 4 speed back in there. that is what i would do if i were you.
all it takes is a jig saw and a chunk of wood.
thanks
Old Oct 10, 2005 | 10:02 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
well that sounds doable... but im missing my connector with the 4 pins... know where i can get one from?
Old Oct 11, 2005 | 02:07 AM
@ZZKKER's Avatar
try the local bumper to bumper, or mabee orielly. both of them seem to have repair kits for blower motor harnesess on other cars, so i would think they would have them for this.
thanks
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
