Painless and oil pressure
Old Oct 21, 2005 | 10:49 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
*cough trickster help cough*
I have a maf style painless wiring harness and i was wondering what my options were for the oil pressure switch. There`are two wires coming from the harness that are both labelled "oil." I'm guessing one is for the guage in the car and the other goes to the fuel pump relay. Is their another option to getting a Tee Fitting and buying another oil pressure switch? Is their a way to splice these wires around, even using a different oil pressure switch?
Old Oct 23, 2005 | 07:09 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Gauge sender and switch are in one unit above the oil filter for 92. 87 has the switch at the filter and the gauge sender next to the distributor.
The switch is not needed for fuel pump operation. It's merely a backup switch for if the relay fails.
Should be 2 wires for the switch. One is connected to the incomming power from the battery to the relay, The other wire bypasses the relay and connects to the power to the pump wire.
My 91 it's orange and grey, my 87 is orange and black.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
