Cig lighter has only worked once since I bought the car.
Old Oct 27, 2005 | 08:10 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I have tried maybe 30 times or something over the course of time I have had the car, and it only worked once...so i know its not broken. it wasnt the first time that it worked either. it was after i tried it a few times weeks earlier.
Old Oct 28, 2005 | 02:09 PM
Firebat's Avatar
take apart your center console to get to the wires that connect to the cig lighter. disconnect the wires. Scratch or sand the contacts where the connectors on the wires went to. There might just be some oxidation on those contacts thats not letting you have a good electrical connection. Clean your cig lighter too, it may help. Also, it never hurts to doublecheck the fuses but unless other stuff isn't working, i highly doubt you have a blown fuse.
Old Oct 28, 2005 | 02:50 PM
ZZ4 86 Z28's Avatar
what else does this fuse control? im not really worried about it, I was just wondering where the fix would be and if something else would be broken with it. thanks for the help.
Old Oct 28, 2005 | 08:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That fuse is the "ACC" (accessory or courtesy) fuse and controls all accessories such as power windows, power mirrors, power seats, cig lighter, interior lights, radio, power door locks, to name a few.
Old Oct 28, 2005 | 10:25 PM
ZZ4 86 Z28's Avatar
ok the its just the lighter. thanks.
Old Oct 29, 2005 | 03:00 PM
BOTTLEDZ28's Avatar
Transmission: A4
I have a similar problem with mine. The lighter goes into its slot but it isnt tight and I cant get it push in and stay in. It just goes in and stays there and it doesnt work either. is there some type of spring in there that might be broke or rusted up? I havent had my dash together in about 6 months and this problem just popped up while I was finishing up the install of the dash. Can I buy a replacement heating element?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
jharrison5
Aug 19, 2015 05:53 PM
apie2546
Aug 8, 2015 07:12 AM
