tpi wiring coolant fans
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i got a 91 speed density harness, and i'm wiring up the power wires, on this harness by the battery on the frame rail is a 2 pin connector with a red wire and an orange wire, the red wire goes to the 20 amp fuel pump relay and the orange wire goes directly to the 2 coolant fan relays
now of course there is a connector that plugs in to it that supplys the power but it joins both of the connections together, where i dont see a fusible link on the coolant fan side, does anyone know what i'm referring to?
Car: 1986 Camaro SC
well the connector i have goes to a ring terminal which is a red wire, i do not have the original battery wire this harness came off of, i guess i could use the old positive cable with the fusible link
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i guess i'm not 100% clear on what you're referring to, then, because the only other fusible links on that harness are on the wires that hook up to the starter terminal for power distribution. the coolant fans have no links on those wires, even from the connector you're talking about.
eightsixseven
Dec 16, 2024 01:50 PM
Sanjay
Aug 12, 2015 03:41 PM
