Where can I get a new one of these connectors (distributor related)
Old Nov 4, 2005 | 03:49 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm converting my 86 wired car to 87+ distributor setup so I need to convert the wiring as well. Where can I get the parts new? I need the 4 pin connector that goes to the distributor and the large wire (looks like a plug wire) that goes from the coil to the cap.
Old Nov 4, 2005 | 03:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can buy a universal coil wire at any parts store. Some stores will have the 4 pin connector too.
Old Nov 4, 2005 | 04:45 PM
Car: 86 T/A
Engine: HSR 355
Excellent. Basically my engine came with the distributor, but no plugs or coil. Do you think stores sell the whole coil holder with wires or do I have to track that down used?
Old Nov 4, 2005 | 04:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That would probably be a dealer or junkyard item.
Old Nov 4, 2005 | 07:43 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Junkyard probably is the best bet. It'll probably only be a dollar, but be careful because that old plastic is very easy to break if you pull the tab much at all. I'd get two!
Ironhead38
Sep 7, 2015 02:26 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
Jlanz55
Sep 6, 2015 03:05 PM
middian
Sep 5, 2015 01:42 AM
