Ignition buzz/Fuel Pump stuck
Old Nov 9, 2005 | 08:08 PM
lostreception's Avatar
Car: 90 Chevy G20
Engine: 350 TBI 5.7L LO5 1227747
Transmission: 700R4 3.42
After i put the key in the igniton i used to hear the ignition buzz (i dont miss it) but my fuel pump stays on for a full 20 seconds not the standard 2 sec ecm prime. are these 2 related to each other
BTW its 20 seconds to the um... "second" is something getting overridden with the ecu? or do i have a loose wire
Old Mar 5, 2006 | 08:01 AM
drdroopy's Avatar
Car: 1991 Firebird
Engine: 3.1 V6
having same problem myself, and it causes my car not to start as well
Old Mar 11, 2006 | 10:51 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
"possible" culprit could be the switch in the ecm. the ecm is what triggers the pump to prime, shuts it off when no crank is signaled. maybe that switch is sticking. i'd try to find (borrow?) another ecm before i "replace" it, though.
9192camaro
16
Feb 3, 2019 12:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
