Ignition module Stock,accel,msd which one? How many pins do I have?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have a accel coil and a msd 6 al I am going to change my module but am unsure of which to go with. I have heard you should get the same one as your coil. also I have the stock 86 LG4 hei dist do I have a 7 pin? if not which one? thanks
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, the module is still in the distributor. Assuming it works now, replacing it will get you no benefit.
tartagliaz28
Aug 15, 2015 10:59 AM
