Windshield Wipers
Old Nov 27, 2005 | 10:23 PM
drews91maro's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Windshield Wipers
Anybody know why my wipers don't work except when they are all the way on? Anybody know if it the motor or a short or anything? I'm pretty clueless...
Old Nov 29, 2005 | 12:16 AM
Firebat's Avatar
wouldn't think it would be the motor. Could be the wiper switch or the wires/connections that go from the switch to the wiper.
Is it going really fast at full speed?
Old Nov 29, 2005 | 07:25 AM
Car: 91 RS Camaro
Engine: 305 TBI
Yeah at full speed they work like new...normally. also when i go to turn them off they always wanna stop where i turn them off at...the sprayers work but the blades won't move...I'm soo confoosed!
Old Nov 29, 2005 | 07:48 PM
Kingsnake2005's Avatar
Car: 86 Camaro IROCZ
Engine: Stock 305 with 89 TPI
Transmission: 700R4 w/B&M transpak
Yeah, i had that same problem with my 86. I believe your 91 is going to have a slightly different setup than mine.. but what i found was a torn up circuitboard in the wiper transmission unit. You might want to carefully take the cover off and check it to make sure it isn't damaged. Also, mine had some switches on it to let the car "know" where the wippers were at. THat switch might be coroded or damaged... Might be worth a look see If it looks ok, i would suspect the transmission unit and look into a replacement. What happened when your car started doing this? With mine the wipers stopped moving and blew the fuse. After i "unstuck" the wipers and replaced the fuse they began to do the same thing. I repaired the circuit board and managed to get the "stop" feature to work but i havent been able to get the delay wipers to work since then.
Old Nov 29, 2005 | 08:01 PM
Car: 91 RS Camaro
Engine: 305 TBI
Yeah it's really wierd, they won't cut on on any other level except full...then usually if i try to cut them off they just stop where i turned the know. I have to play with the **** a bit until it fiannly goes to the correct place
Old Nov 29, 2005 | 08:08 PM
Right, except did it happen all of the sudden or did things just slowly stop working E.G. Low and High work, but Delay wont... Then high works with no low or delay.... finally, a few weeks later, high works with no delay, no low speed, and now the wipers wont return when switched off....
Old Nov 29, 2005 | 10:41 PM
Car: 91 RS Camaro
Engine: 305 TBI
Yeah kinda...it started that way then for a while every thing was working great...then one day they decided to do what they are doing now
Old Nov 30, 2005 | 02:31 AM
Hmm, it still could be any one of the three... assuming the system hasn't experianced any trauma, the transmission and wiring should be ok. I would start out with the switch as the first culprit, if all is ok there, the transmission, i really dont thing it could be the wiring unless it is the wires in close proximity to the multifunction switch/turn signal/curise etc unit. Try tweaking it slightly this way and that to see if you can get any continuity out of it... "change the symptoms" This could help you narrow down where the problem is located... Tap on it, switch it, tweak it, try switching it while in the down position, up position, high-beam switch, etc. Let me know if anything changes while you are doing this. I think an easy test would be to stop your wipers half way up your winshild. Place the switch at the off position. At this point the wipers should return... If while your tapping and tweaking the wipers start to return youll know your on the right track. IF not, move to the wiper transmission unit... Unplug all the electrical connectors and plug them back in- repeat two or three times... see if that makes a difference
Old Nov 30, 2005 | 07:25 AM
Car: 91 RS Camaro
Engine: 305 TBI
This will be my first time wessing with this...where is the Wiper Transmission Unit? Is it under on my steering column or under the hood? I have no clue
Old Nov 30, 2005 | 07:21 PM
It should be under the hood to the passanger side of the brake booster mounted on the firewall
Old Dec 1, 2005 | 07:24 AM
Car: 91 RS Camaro
Engine: 305 TBI
alright, I appreciate the help! I've been needed to get around to this, so I better do it this weekend!
Old Dec 15, 2005 | 05:43 PM
dariat's Avatar
If your able to fix it, could you let us know what worked?
Mine is currently doing the same thing.
Usually you have to turn it to high just to get them to move. Sometimes after running for a bit you can turn it down and get luck and it will run at low and even delay. usually when turning it off it will stop right where it is. If you fiddle with it for bit, it will eventually go off. Sometimes after getting it off after about 5 minutes it suddenly will come on for one swipe then go off again.
Hope it's not too expensive to fix.
-Thanks!
codeysabatini
Nov 10, 2015 04:07 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
