HELP! Passenger power lock unlocks by itself
Old Dec 3, 2005 | 02:46 PM
BDK's Avatar
BDK
Car: '01 Z28 , '88 WS6
Engine: LS1 , LB9
Transmission: 4L60E , 700R4
We had some heavy rain/freezing temps here in north NJ the past few weeks. I finally got my new alternator on and reconnected the battery after 2 weeks of sitting, and now the passenger side power lock keeps unlocking by itself?!!! I am just stumped. I walked back outside to reconnect my intake tubing and put everything back together and heard this clicking about 10 feet from the car. I thought maybe the power hatch motor went, but after further investigation, only the passenger side power lock keeps unlocking by itself. I locked it manually and it just pops back in the unlocked position. I would appreciate any help. Thanks!
-Noah
Old Dec 5, 2005 | 12:13 PM
Firebat's Avatar
did you leave it outside for two weeks during these heavy rains. If you did, i'm guessing you got some water where it isn't supposed to be and its causing a short of some kind. Probably a short across the switch or the relay. For a temporary fix, put the car somewhere dry for a couple days and see if it still does it. Long term fix - check out all the wires and connections and try to waterproof them better.
Another possiblity is you could have a bad unlock switch or a bad relay.
Old Dec 5, 2005 | 01:02 PM
Vader's Avatar
But it's odd that only one dorr unlocks. A bad/wet switch should unlock both simultaneously. Water in those membrane switches can do that.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
stalkier
Aug 21, 2015 01:54 AM
