TBI Injector problem!!!!
Old Dec 13, 2005 | 09:08 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
We just got finished swaping the 700R4 to a TH350 in his 87 Camaro. We went to fire it up and all it did was spin over, the injectors arent squirting fuel. We tried changing injectors and nothing. We know it is elitrical but are geting annoyed with it. All we did is take off the distributer cap so we wouldent crack it in the swap. Any ideas?
thx in advance
Old Dec 14, 2005 | 08:13 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check your wiring on the right side of the engine and see if you may have broken or pinched a wire. Also check your ground wires on the back of the cylinder heads.
Old Dec 14, 2005 | 03:55 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
When we took the other trany off there was a ground between the bellhousing and the block, wich we forgot to put back so we just put it on the firewall. Could this be our problem???? We dident trace the ground back so i have no clue what it goes to.
thx in advance
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
