iroc z please help!!
Old Jan 2, 2006 | 06:04 PM
2badcams's Avatar
Car: a 91 rs convertible and a Iroc z convertible
Engine: 305 tbi, and 350 tpi
i just bought an IROC Z convertible and i got it cheap because it had some sort of electrical problem. i thought it would be easy to fix since i've had this problem or a similar one with one of my friends camaro. however im starting to get stuck and have no idea what to do next. the problem is that when i go to turn the car on the instument panel lights up and everything looks good as if the car was going to turn on but it doesnt. the starter doesnt even crank at all! what could it be? please help!
i was told it could be a vats problem any ideas???? thankx
Old Jan 3, 2006 | 02:24 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Neutral safety switch?
try putting the car in neutral and starting it.
Old Jan 4, 2006 | 12:26 AM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
what year is the car and if the secuity lite is on and you can't here the fuel pump you have a vats problem
Old Jan 4, 2006 | 01:23 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Fuel pump will prime weather the security light stays lit or not.
I've been fighting this random not wanting to start problem on my 91 as well. Mine has the exact same issue and appearently has something to do whith the little thin wires that run up to the key cyl that 'read' the resistance in the key 'pellet'.
The security light was staying on. Pump primed no matter what. Gauge lights went off during crank. Temp gauge did it's sweep. Not much else happened though in the way of starting. Not a peep as far as relay or starter noise.
If the car is not vats quipped, I'd take a stab at the NSS as LT1 stated.
Old Jan 4, 2006 | 03:42 PM
2badcams's Avatar
thanks guys
hey guys...well thanks for all the info i havent tried anything because it has been raining over here but i will as soon as i can work on it. so yeah i had the same problem with my 91 camaro and i thought it was the alarm because i had remote start function on it... so the guy who i took it to did something to it so that now i can only turn it on with my alarm still, but not with the key...so its not back to normal but it turns on! i guess the only problem would be if something happens to my remote.
but like i mentioned before now the problem is with my IROC Z CONVERTIBLE!!!! so i will try the stuff that my fellow camaro drivers advised me to do and repost any results so that they may help in the future if anyone has the same problem... thankx
Old Jan 4, 2006 | 03:46 PM
2badcams's Avatar
the car is a 90 iroc z 305 tpi
Old Jan 4, 2006 | 10:55 PM
driver101's Avatar
my 91 will prime the pump but wont crank unless the vats is hooked up thought this might help but i will keep trying things out when you let me know more
Old Jan 4, 2006 | 11:58 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Re: thanks guys
I have Remote start on my 92 GTA and my 91 GTA Convert I had the same problem......When the hook up the remote start they have to bypass the VATS they use a resistor in the line to do this.....Unfortunately they didn't wrap the resistor with anything and because the 91 & 92 have that metal based panel under the dash that replaced that crappy plastic one of the older cars the resistor was touching that changing the resistance and not allowing it to start.....Bottom line make sure those wires going from the ignition to the VATS are not shorting out
Old Jan 5, 2006 | 01:28 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I had the same problem and it had to do with VATS. I had to replace the ignition switch cylinder.
Old Jan 5, 2006 | 04:29 PM
2badcams's Avatar
where is the ignition switch? is that the key insert?
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
