no lights
Old Jan 5, 2006 | 11:05 PM
rokn91rs's Avatar
no lights
i have a 91 rs. my headlights, taillight, dash lights, and door locks do not work. i checked all the fuses under the dash. any suggestions on what to check next would be helpful.
Old Jan 5, 2006 | 11:16 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Did you have to replace the ACC fuse? I know my cigarette lighter shorts out the Accessories circuit (although I don't think the headlights are on that circuit). Even when I put in a phone charger the fuse blows. ALSO, sometimes when I stepped hard on the gas, sparks would fly out of it. YEA. I took a screwdriver to the inside and bent the prongs in so they don't contact the inside. No more sparks. (I'll replace later).
SO, make sure your cig lighter isn't shorting out your ACC fuse.
Old Jan 5, 2006 | 11:31 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
If that does not work check the fusible links. I am not sure if they have anything to do with interior stuff and if that does not work start looking for a loose ground.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
