4th gen dash swap
Old Jan 14, 2006 | 10:27 AM
shortbed454's Avatar
4th gen dash swap
i know this may not be the correct place to ask this question but i dont know where to look for helpand i know a fewof you guys have done the swap into your 3rd gens. im installing a dash out of a 96 firebird into my 79 camaro and i need to know how i would go about making the speedo function correctly. if i were to adapt the correct vehicel speed sensor and reluctor ring onto my trans, could i just run the wire/wires into the connector on the back of the instrument cluster. any help would be greatly appreciated.
Old Jan 14, 2006 | 11:07 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the vss will need to be buffered through the computer. Assuming you are running an LT1, the computer needs to know the vehicle speed also and then relays the information to the gauge cluster. I have the same thing in my car and I can shoot you some diagrams and routing if you need.
Jorlain
Aug 24, 2022 05:11 PM
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
