speedometer sender questions
I am looking for the signal wire!!! I have two wires coming out of the sender unit. A tan/black stripe and a Black wire. I measured the resistance from the tan/black wire and it showed a short. The black wire shows about 50KOhms. I thought it was the tan/black wire but now I am not sure. My books shows the black wire going to chassis gnd, but it doesn't.
Next question.... Can I run two speedometers from the one sender unit?
That's odd. My '86 has purple and yellow wires from the VSS:
Usually, GM is fairly consistent in their wire colors.
The tan/black wire is probably your TCC solenoid in the transmission, and should actually be about 35-50 ohms, not shorted.
NBrehm
Aug 25, 2015 11:49 PM
