Changed steering wheel, AirBag lamp.
Old Feb 9, 2006 | 07:58 AM
327 iroc's Avatar
Car: ´86 Camaro IROC-Z/28 T-top
Engine: 327 (331)TPI
Transmission: th700r4
Axle/Gears: should be 3.73
Hi
How can i put out the Air bag lamp on my -90 camaroRS??
Have enyone changed one before?? (most likly)
Can i cut the lamp cable from the ECM?? and if so, how do i find it and know its the right one??
Old Feb 9, 2006 | 08:00 AM
Drew's Avatar
Remove the bulb.
Old Feb 9, 2006 | 08:38 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
Old Feb 9, 2006 | 10:21 AM
327 iroc's Avatar
Originally posted by Drew
Remove the bulb.
OK, i had a look at it and it seems to be quite difficult, or is there an easy way??
Thank you for the tips so far
Old Feb 9, 2006 | 05:53 PM
jimp2001's Avatar
Engine: LO3 305 TBI
Take off headlight ****, remove cluster trim panel, take out 2 nuts that hold the cluster in... pop out cluster, remove bulb, and put back in.
Old Feb 10, 2006 | 07:37 AM
327 iroc's Avatar
Much thanks to you all for the help
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
