radiator fan
Old Feb 27, 2006 | 03:35 PM
start'er up's Avatar
Car: 1988 pontiac trans am
radiator fan
i have an 88 trans am with the 5.0 l v8 (F) and it seems that the fan kicks on at a certain temp. and it is running pretty hot, so i was wondering how i could get the fan to kick on earlier, even though it is a HO engine, i still think its running a little hot, and what is the best running temp for this?
JRance
sorry, this should go in cooling! my bad
Old Feb 27, 2006 | 11:29 PM
Vader's Avatar
You have a couple options. You can reprogram the ECM with lower fan temperatures, or you can install a parallel fan switch to control the cooling fan realy at a different temperature. I did both.
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
