regular ignition to hei conversion
Old Mar 21, 2006 | 10:49 PM
CamaroSS_Black's Avatar
Car: 1986 Z28
Engine: L98 Block Vortec Heads Comp Xtreme
Transmission: Built 700R4
Axle/Gears: 10 bolt with Auburn 3.73 posi unit
is there anything that i should know about this or is it cut and dry
Old Mar 21, 2006 | 11:08 PM
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
Define 'regular' ignition? Points? Your 1986 should have HEI already.
Old Mar 28, 2006 | 02:47 PM
Car: 1986 Z28
its an 87 and it has points not hei i have a 350 with an hei and i want to drop it in the 87 but i need to know if there is anything special that i need to do
Old Mar 28, 2006 | 03:31 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I guess that would depend on how much of your original car still exists. If the original harness and computer is still there, just plug it all in. If it's not, then you'd probably want one with a vacuum advance, then you've basically just got power to hook to it.
2012sergen11
Oct 13, 2015 07:38 PM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
