TPS voltage
Old Mar 29, 2006 | 09:04 PM
Blackhawk355's Avatar
Car: 1989 Firebird
Engine: N2O 355CID
TPS voltage
whats the voltage suppose to be on the tps sensor? i think im having one take a dump on me.
Old Mar 29, 2006 | 09:40 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
between .45 and .50 volts.
Old Mar 29, 2006 | 10:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
2.8 vinS = o.55v ± o.1ov
5.0 vinE = <1.25v
5.0 vinF = o.54v ± o.1ov
5.7 vin8 = o.54v ± o.1ov
It's better to test the TPS with an analog voltmeter and watch for a smooth rise in voltage with the throttle opening.
Old Mar 30, 2006 | 12:06 AM
Car: 1989 Firebird
Engine: N2O 355CID
ok, done that, its showing .49 constant and not increasing nor decreasing when i open and close the butterfly, is it safe to say it's bad or am i not doing something right.
Old Mar 30, 2006 | 12:46 AM
1981LT1's Avatar
Engine: LT1; LT1
If you feel that you are testing it correctly, then I would say it is toast.
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
