fire and fuel no start
Old Apr 7, 2006 | 10:50 AM
hotdaddysturn's Avatar
Car: 91 firebird
Transmission: auto with o/d
i have a 91 firebird 305tbi has fire and fuel but wont start after i have changed timing chain and gears.dist cap,rotor,wires, plugs, 02 senser, temp senser,fuel filter,tryed to set timing but wont start.
Old Apr 7, 2006 | 10:55 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
if u have spark and fueling, its a timing issue.
Old Apr 7, 2006 | 05:01 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Turn your motor over by hand untill the timing mark lines up with zero then check the rotor, if it is not pointing at the #1 tower turn it so it is.
Old Apr 8, 2006 | 07:39 PM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
also, i hear when you do your timing, you have to disconnect the timing advance to the ECM or else its going to be WAY off. Not sure where that is, but might be something to keep in mind.
Old Apr 8, 2006 | 09:02 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
the piece that you have to disconnect is the spout. it brings the engine to base timing. What dist. do you have on the car? is it a vacuum advanced older style one or is it the factory computerized one.
Old Apr 17, 2006 | 05:02 PM
Car: 91 firebird
sry for not replying sooner,we found the problem in the coil itself ,misfiring got new coil started up but rough need to set timing now
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
