infl light?
Old Apr 14, 2006 | 08:29 PM
BowtieDriver2's Avatar
Car: '01 sonoma & '91 camaro
infl light?
I have a freind that has a 92 camaro 3.1 that will not start. the idiot lights come up but nothing else seems to work. he said the infl light stays lit. is this the airbag system? would this keep the car form starting?
the car will not try to turn over, fuel pump isn't priming, just the idiot lights. any ideas???
Old Apr 14, 2006 | 08:40 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes it is the airbag light and no it won't prevent the car from starting .
Lon
Old Apr 14, 2006 | 08:45 PM
any idea why there would be no power. or why it wont even try to start?
I dont think ground because the idiot lights are coming up. I dont think starter relay because no fuel pump priming.
I am kinda lacking for ideas.
Old Apr 25, 2006 | 04:51 PM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
VATS
your problem is most likely your VATS if your key has a chip (resistor) on it then that is your friends problem you need to replace the key cylinder or cut the wire from the key cylinder and on the wire going to the computer solder a 10ohm resistor and it should work
Old Apr 27, 2006 | 03:03 PM
88TTFB's Avatar
Car: 88 TA
Engine: 5.7 TPI
Some cars had a fuel pump cut off linked to the airbag. I dont know if 3rd gens did but it may be so.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
