Ignition question
Old May 6, 2006 | 06:04 AM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Ignition question
Has anyone ever heard of having spark at the beginning of cranking then it would go away after a few seconds? Is my module going? Or am i just seeing things. It won't start and I'm running out of thoughts of what it could be.
Old May 6, 2006 | 04:02 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Check power and ground at the coil.
Old May 6, 2006 | 07:53 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Did it voltage is good, ground is good. I replaced the module just to be sure still the same. I'm starting to think the ecm is bad. Any suggestions?
Old May 6, 2006 | 08:00 PM
Brads RS's Avatar
Did you check the pick up coil inside the distributor? I have come across a similar problem and found that the pick up coil was falling apart and not doing its job fully.
Old May 6, 2006 | 08:41 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
yes I checked it. It looked in good condition and I checked it per the manual It read 975 ohms or something I don't remember exactly. So its within specs. This is just racking my brain because I do have spark, Its timed right, there is compression, and I even changed the carb to rule that out and unless that one is bad too I don't know where else to go. Right now I have the timing cover off and I wanted to check to see if it jumped a tooth or something but its right on, the chain is a little loose so I'm going to change it but I don't think that's the problem. I'm thinking maybe the knock sensor is bad retarding the timing when I crank it so enough it won't start or the computer may be bad. That's what's next unless someone can point me somewhere else.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
