mallory unilight distributor
Old May 14, 2006 | 10:02 PM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
where is the no 1 on the cap
Old May 14, 2006 | 10:44 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
Wherever you want it to be.
Take the distributor cap off. Take the number one spark plug out. Put a breaker bar on the bolt in the middle of the crank, put your finger in the spark plug hole, and slowly turn the crank clockwise. When you feel/hear air escaping through the hole watch the timing mark on the balancer. When it gets to TDC, make a note of where the rotor is pointing in the distributor. Put your cap on and run the wires with #1 at the mark you made on the distributor. Set your timing and you're good to go.
Old May 14, 2006 | 11:10 PM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
thankx,tomorrows the day i start it after the swap
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
2012sergen11
Oct 13, 2015 07:38 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
