bat relocate
Old May 22, 2006 | 11:13 PM
85blackberlinet's Avatar
Car: 85 berlinetta
Engine: none
Transmission: 700r4very soon t5
bat relocate
hey what type and gauge of wire should i use to put my battery in back
Old May 23, 2006 | 05:33 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
At last 2 guage. Many people use 0 gauge to be safe thought. I would consider this overkill. 2 gauge will be just fine unless you are running a very high compression motor with a torque recuction starter that pulls alot of amps.
Old May 23, 2006 | 09:04 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I used 1/0 Welding cable running to a distro block in the bay (and for my batt to frame GND) then 4 Ga running from the distro to the starter.
I would have run 2/0 but they were out of it at the time
Whatever you decide to use make sure you check your voltage drop from the batt to the starter (or wherever you run the + cable to).
Old May 23, 2006 | 11:53 AM
Car: 85 berlinetta
Engine: none
thank you
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
J.C. Denton
Sep 21, 2015 04:23 PM
89newfun
Sep 16, 2015 09:28 AM
