pulsating lights
Old Jun 1, 2006 | 02:51 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
pulsating lights
on my 86 ta the head lights and are pulsating as i drive ligthly. Any idea on what is causing this to happen?
Old Jun 1, 2006 | 04:12 PM
Firebat's Avatar
bad alternator is my guess
Old Jun 1, 2006 | 04:46 PM
Blue-Z28's Avatar
Car: 86 IROC-Z
Engine: 305 tpi
Old Jun 1, 2006 | 07:25 PM
W72's Avatar
W72
Car: 89 GTA & 92 T/A covertible
Engine: 408LS-SC, 355 TPI
Transmission: 4L80e, 700r4
Axle/Gears: 12 bolt, 9 bolt
I had this problem with my Can am which has the earlier Delco 10si alternator. Whenever the engine RPM was below 1200 or so the headlights and dash lights would pulse. I tried everything, from gound wire replacement to belt replacement. The old aternator was freshly rebuilt and had worked well for a year,I even took it to a shop and put it on a test jig and it had a solid 14V output. I ended up just putting another kit with diode trio,regulator, bridge rectifier and brushes in it and the problem went away.
If I had to hazard a guess I would say the bridge is bad.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
