2000 Camaro V6 Wiring....
Old Jun 14, 2006 | 10:46 AM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i picked up a dash from a 2000 camaro.. but the cluster is a v6...i will prolly not use it and get an lt1 cluster 97 V8...BUT...can i still use all the wiring for the headlights, trunk, fog lights, cluster?
Old Jun 14, 2006 | 03:11 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
The wires may not be the same length and the connectors may not be the same type, especially with the lights. Also your head light motors will not work because the Camaros didn't come with hidden head lights like the Birds did. Best bet is to get a similar year, or another Bird's harness.
Good luck!!
BTW, nice engine setup, have any HP ratings?? Havent dynoed mine and curious to know what you are getting, very similar to mine, thanks in advance!
Old Jun 14, 2006 | 03:54 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i plan on splicing wires to the 4th gen connector...
Old Jun 14, 2006 | 04:59 PM
Ok, makes sense. As long as everything is done right you shouldn't have to many problems. A chasis harness is very similar within all GM cars, other than length and connecters they really aren't that much different....unless it is from a car with a lot of options, and vice versa.
