Is there a way to jumper the fuel pump relay
Car: 1992 Camaro RS Convertible
Engine: 305 TBI
Axle/Gears: Not sure, but guessing 2.2
To start, I have done a search and gone through many, many pages on this and still am at a loss.
I am have a no start issue and I have spark, but after testing the 3 prong plug in the rear that leads to the fuel pump I have low voltage to the center pin and nothing on the outer 2.
Also, I am not hearing the fuel pump prime when I turn on the car.
I put a new fuel pump relay on and still nothing.
I have constant power at the orange wire, but I am not getting anything else on any of the other wires when the key is turned on.
I read about putting 12 volts to the G terminal, but I dont seem to have a prong in the G terminal spot.
I would just like to be able to jumper the relay before I purchase another relay.
Any help would be appreciated
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It looks like you have a '92 so right next to the right hood hinge there is a red wire with a black plug on it that is the fuel pump prime wire.
