Headlight Issues...
Old Jul 14, 2006 | 01:41 AM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
Headlight Issues...
ok the problem started today....
whats wrong
1. Driver Side Light is Dim, Passenger Side is normal
2.They Pop Up From Down Without A Problem
3.When i turn them off they dont go down, but instead the motors make a clicking sound like their trying to go down in really slow motion
4.If i unplug the drivers side motor from underneath the passenger side goes down without a problem
5.earlier on in the day it happend aswell but i jiggled a wire loom by the drivers side light and they worked perfect after that... then i decided to try them a little later after a short drive and their acting up again...
now thats all the info i can think of right now... does it sound like a loose ground? or possibly the headlight doors module going? if these are the common symptoms to something.. what are they for?
Thanks!
Old Jul 14, 2006 | 02:28 AM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
ha at least yours still work i tryed everything new relays and all and no matter what i do mine are stuck up
Old Jul 14, 2006 | 02:37 PM
jethawk's Avatar
Engine: LB9
Axle/Gears: 3.42's
went outside to work on her today.. and it was just a bad ground....tightened the bolt up and now she works perfectly again!
Old Jul 14, 2006 | 03:55 PM
'86 350's Avatar
Car: '86 Camaro SC
Yep, a bad ground is usually the main cause for dim lights and other things you mentioned.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
