guage fuse always popping???
Old Aug 10, 2006 | 02:07 AM
91thirdgen's Avatar
my guage fuses are continually popping it is supposed to0 take a 10 amp fuse but it will pop a twenty i think it may be a short to ground.. help needed please byt the by i drive a 91 z28 305 tpi auto
the only electrical changed is my stereo system and aftermarket foglights?? what could go wrong?
Old Aug 12, 2006 | 01:19 AM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
you should mention kyle that its a 1991 Z28.... 305 TPI Auto
Old Aug 13, 2006 | 12:58 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I had this problem years ago. It turned out to be a short.
Old Aug 14, 2006 | 08:39 PM
91thirdgen's Avatar
what was shorting because i got the wiring scematic and that circut is full o stuff and mine is possinbly the same problem so what was shorted on yours?
Old Aug 15, 2006 | 10:57 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
Just so you know, putting 20A fuse in 10A socket = more problems than just another burned-out fuse. That's a good way to burn your car to the ground.
That 10A fuse protects the wiring for that circuit. Putting in a 20A fuse allows more current to pass through the wire (probably from a short in this case), which is more than the wire for that circuit is capable of carrying while dissipating heat caused from (I^2)R losses , and therefore cannot dissipate the extra heat. The wire will get very hot, melt the insulation, catch things on fire....
Just a warning in case you did not know the potential consequences.
Old Aug 15, 2006 | 11:01 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
The fuses that are blowing aren't by chance the ones for the circuit that you plugged your stereo system or fog lights into is it?
For example, it would be bad to run either of those things from a 12V wire used for something like the radio, or another accessory wire or anything like that.
Old Aug 15, 2006 | 11:03 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
Double post...stupid database error.
Old Aug 17, 2006 | 12:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
IIRC the cigar lighter is run from the gage fuse. I've seen where the lighter body shorts to the shell popping the fuse. Just put the cigar lighter in the console for a while and see if the fuse stops popping.
RBob.
Old Aug 17, 2006 | 12:46 PM
jethawk's Avatar
Engine: LB9
Axle/Gears: 3.42's
i think he found the wire... it was in the lever and had to do with the cruise control... but its been a couple days since ive talked to him so i dont really remember
Old Aug 17, 2006 | 01:56 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Not sure what the cause of mine was. I had an electrician fitting an alarm and CD player so he came back out and fixed the short also.
sheachopper
Jul 31, 2019 11:27 AM
Luigytico09
Oct 1, 2015 08:46 AM
