How do I check coil output?
Old Aug 12, 2006 | 09:48 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
How do I check the output of my ignition coil?
Old Aug 12, 2006 | 10:30 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
don't know how to test output but you can test the resistance between two connections to test the health of the coil. Most shop technicians test coils the easy way, install a good used coil and see if the problem goes away.
Old Aug 14, 2006 | 03:22 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
With a coil tester of course.. That's no joke, but it all depends on the purpose of the test, what's the background for your needing testing..?
It can range from pulling one spark plug lead and see how far the spark will jump, to measuring resistances, and finally to using advanced test instruments to measure peak voltage [kiloVolts], peak current [milliAmps], spark duration [milliseconds], and spark energy [milliJoules]..
Old Aug 18, 2006 | 09:54 PM
rjpbboi's Avatar
I actually already used blkbird's suggestion and just swapped it with a different coil, my friend let me "borrow" his from his GTA and it turns out that mine was bad...
Old Aug 20, 2006 | 02:18 PM
Always nice when there's a quick & easy way to solve a problem.
I gather that your car didn't start then..
Old Aug 20, 2006 | 05:10 PM
rjpbboi's Avatar
Nope wouldn't start, and I hadn't hada coil problem before so I just went throught the entire system, air, fuel and ignition before I found the coil. Swapped it with my friends and the car started right up, and runs fine, for now...
Old Aug 20, 2006 | 05:19 PM
Yes, glad you solved it without getting grey hairs! There's always that first time, and nothing beats a systematic approach.. Oh yes, you can bet that somewhere down the road you'll be put to the test, again... ;D
92camaroJoe
Jul 29, 2023 07:57 PM
mddaniel
Sep 8, 2015 05:16 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
