Lights
Old Aug 21, 2006 | 04:01 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Lights
Ok I have a 1990 with no ECM hook up, how do I unwire
the INFL REST light without removing the dash bulb
so that it does not come on and the security light as well
since it did operate from the ECM and the VATS etc. ?
Thank you
Old Aug 21, 2006 | 09:51 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Lights
well as a thought I will try to disconnect all the SIRS wiring and the relays and modules that it uses to see
where this leads. I thought someone might have done this elimination when they went to a NON-ECM car ?....
Old Aug 23, 2006 | 10:59 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
TTT
Old Aug 23, 2006 | 11:04 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
I know to disable the airbag you just have to unplug the yellow terminal plug at the base of the steering column. I don't know if it will kill everything related to the air bag though. This '92 I'm tearing down had two sensors/actuators under the console. From what I understand everything with yellow plugs is related to the airbag.
Old Aug 23, 2006 | 11:08 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Lights
Tried the airbag today unplugged it and same with the dash, when the headlights are on the guages shut down, now when I turn the dimmer to off then they come back on
weird annoying problem.....trying simple stuff first.
Old Aug 23, 2006 | 11:38 PM
2kflhr's Avatar
Removing the dash bulb is real easy. Takes about 15 minutes.
Old Aug 24, 2006 | 10:08 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Lights
really looking for a way not to remove the bulb maybe find the wire to it and cap it off.....as the more bulbs you remove the less light you have on a crappy lit dash alreadt lol.....
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
