Can I use this as a remote power door lock key?
Old Sep 17, 2006 | 12:51 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I got two sets of these when i converted to flushmount headlights. Can I wire them up to my power door locks to be able to push the button and open up?
Heres a diagram! I have a good idea to wire them up I would just like to see if im wasteing my time or not. besides its a free mod
Old Sep 17, 2006 | 05:50 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
a remote lock and unlocksends a pulse signal, meaning it is only energized for 1 sec or so. that remote is designed to send a signal untill you hit the next button. the lights stay on right? that is because the sircut is still energized.
I just put in a keyless entry into my 89 camaro today. it cost 30 bucks at pep-boys here and is made by bulldog. 5 wires hookup. pulled my door panes on the drivers side found the lock and unlock wires (Light blue was lock, black was unlock) ran the wires through the grommet to the under side of the dash, hooked two wires to ground and one wire to 12V constannt. that was it.
Hope this helps.
Old Sep 17, 2006 | 08:45 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
weird my power lock wire color was tan and white (right to the motor). i never did hook them up to the lights. However I looked at a multi remote kit today and it was nearly identical to what I have now. I will give it a shot.
Old Nov 7, 2006 | 02:27 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
is it possibe to use a later model gm keyfob and wireless system? i dont like aftermarket ones too much.
thanks
Old Dec 17, 2006 | 02:23 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I see no reason why not.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
