Someone EXPLAIN HEI dist.
Old Sep 22, 2006 | 02:13 AM
1fast97gsx's Avatar
What exactly is different from an HEI distributor and a stock one? How can they be told apart by looking at them? I saw the hei offers either a remote coil or a coil that's mounted on top, with a coil mounted on top it's obvious, but what about remote mount? Just trying to understand what the difference is and also what the functions of EACH pin on the igntion module is. Thanks!
Old Sep 22, 2006 | 02:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Stock distributors are all HEI. HEI is GM's name for their electronic ignition systems used since about 1975 or so.
Old Sep 22, 2006 | 04:17 PM
1fast97gsx's Avatar
So when people refer to remote coil mount hei that means the coil just isn't mounted directly on top of the distributor, but rather a bit away from it?
Old Sep 22, 2006 | 06:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, the "remote coil" or "small cap" HEI uses a separate coil. The "coil-in-cap" or "large cap" HEI uses the coil mounted inside the cap.
Old Sep 22, 2006 | 06:52 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
wasnt there a arcing issue or somthing with the small cap hei ?
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
skinny z
Oct 5, 2015 06:23 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Damon
Sep 26, 2015 04:29 PM
