Heater blower...Where is the ground wire to it?
Old Sep 23, 2006 | 07:34 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
i cant find the gound wire i am gettin 12v from my puple lead but the motor still wont work so i need to check th ground but can find it thanks im out there on it right now so ill be back to check.
Old Sep 24, 2006 | 11:07 AM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
the ground is usually a single black wire connected to the body of the blower by a clip on one of the screws that hold the unit on the plastic case.
Old Sep 24, 2006 | 11:41 AM
Car: 89 Iroc
Engine: 5.7 TPI
alright so mines has 2 black wires a bigger wire and a smaller black wire both go to the same connector nd plug into a clip that is on a screw but those wires show no ground so re-run a ground to it? Also the purple wire in the 4 inserconnector on top of the blower shows a constant 12.3 v evne when the ignition is off and the other 3 dont show anything on and of the setting well one shows 12.3 on high speed but the other 2 are 0 thanks.
Old Sep 24, 2006 | 01:05 PM
Car: 89 Iroc
Engine: 5.7 TPI
ok so i figured it out just incase anyone else has a smimmilar problem. like i had said earlyer my ground connection had 2 black wires comming off of it a big wire and a smaller wire. Turns out the big wire was giving it a constant hot 12v feed for what ever reson i dont know. so i cut that wire off and ran my own ground wire to where that 12v black wire had been hooked up and boom it works. im not sure what the small black wire is but its needed with the ground on that same connector for the motor to work.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jae992
Aug 27, 2015 09:07 AM
