Fuel Gauge working poorly
Old Nov 2, 2006 | 06:56 AM
SaiyajinXero's Avatar
Car: 94 G20 hi-top conversion van
Engine: 350 TBI
Axle/Gears: something vanny
I have a problem with my fuel gauge. It works, but it only works when the float reaches the very end of its travel, being when I have an empty tank. I took the sending unit out of the tank and just played with the float with my hand and about the first ½ inch of travel the gauge goes from empty to way past full, and the rest of the travel is useless. Does anyone know how I can fix it so that it works properly? Is there a way to adjust the variable resistor? I can't find sending units for sale at the parts stores and the float seems to be welded as part of it. Any help would be greatly appreciated.
Old Nov 2, 2006 | 07:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Unfortunately, the gas gauge is one of the common problems (i.e. disasters) in our cars. Frankly, I'm not sure that there is a definitive "fix." You might consider a search for more info though: The topic has been covered many times.
JamesC
Old Nov 13, 2006 | 04:17 AM
Engine: 350 TBI
I found some sheared wires coming from the gas tank that are touching eachother/chassis so as soon as I pull those away and tape them up it should work. busy with a stupid camshaft replacement at the moment though
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
