losing power
Old Nov 29, 2006 | 10:09 AM
406maro's Avatar
Car: 1986 Camaro Berlinetta
Engine: 406 roller
Transmission: th 350
Axle/Gears: 4.10
losing power
ive went through the search feature and couldnt find any similiar problems. So im posting.
When i turn my lights on in my 86 berlinetta it kills the power to my gauges. The interior gauge lights come on, but all my gauges like oil pressure etc... quit working.
Another problem im having is when i step on the brakes my blinkers come on and stay constantly on until i let off the brake pedal.
Any solutions or reccomendations would be helpful. thanks
Old Dec 7, 2006 | 12:42 AM
RY-Rai8ers's Avatar
Car: 89 Iroc
Engine: The 350
Your blinkers dont have a good ground, so when you apply your brakes the blinkers are feeding off that circuit. Thats my guess
Old Dec 8, 2006 | 01:26 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The guage problem is probably located in the cluster. The cluster "backlighting" and the power to the gauges all flow though the printed circuit on the back of the cluster. Could just as easily be in -or- on the cluster circuit boards as well.
As far as the blinkers / brakes,........... Sounds like a bad ground or a failing Light Module to me. If you have done recent work to your car make sure you didn't Pinch a ground wire putting everything back together. If there was no recent work - it's probably the Light Module !
Old Dec 8, 2006 | 09:03 AM
406maro's Avatar
Engine: 406 roller
Axle/Gears: 4.10
ill check on that. thanks for the responses.
formula_novice
Sep 5, 2015 03:58 AM
Slush92RS
Sep 2, 2015 08:56 PM
sailtexas186548
Aug 24, 2015 10:11 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
