Intermittent spark?
Old Dec 4, 2006 | 02:11 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Intermittent spark?
If you take the cover off the coil,(in cap type) and take the leads off the dist cap and then crank the motor should there be a spark from the coil to each post
as it turns over?.I've done this and i dont get spark at the number 8 post.I'ts a msd coil and,it does'nt seem to do this with the old coil. Thanks.
Alicat.
Old Dec 6, 2006 | 02:49 AM
alicat's Avatar
Axle/Gears: Stock.
Does anyone know this?.
Old Dec 9, 2006 | 07:11 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
If # 8 stands out with a missing spark then I'd suspect the cap has a crack or a carbon track. Remove it and inspect/ exchange. Cleaning (and siliconing) a track (or the whole cap) might also be possible.
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
