Gauge lighting question
Old Dec 4, 2006 | 05:55 PM
a13rodie's Avatar
Car: 90 Iroc
Engine: 5.0 TPI
Transmission: 5 speed
Hi there, I recently bought my first car, a 90 Iroc, and have slowly been trying to bring it back. One of the things I've bought is some reverse glow gauge covers. But as it stands right now (without installing the reverse glows), only half of my tack lights up. I was wondering if I should go through and replace the bulbs in it, or if it is a fuse problem. Tried to search but I'm a n00b
Thanks alot in advance
Old Dec 12, 2006 | 10:46 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
On the 90 clusters there are 4 bulbs that light up all the guages, looks like one of them has blown out. If your installing the reverse guages, I don't think you will need to worry about replacing that bulb. If it was a fuse problem then none of the bulbs would be working, nor the cig lighter.
Old Dec 12, 2006 | 02:15 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I installed reverse white face gauge covers and left the blubs in that was a mistake. The stock bulbs interfered with the appearance of the reverse glow.
I soon began to hate the reverse glow and removed them. I'm going to use the stock lights with colored blubs instead.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
