Why do i keep blowing the TAIL fuse ?
Old Dec 8, 2006 | 06:17 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Immediatly after i pull the headlight **** the fuse blows, i read that i should test all my bulbs from the outside to the inside, i did this none were bad... So that means i probbably have a ground somewhere, how do i trace the wires back to the faulty one ? Where do these wires run inside the car ?
Old Dec 8, 2006 | 07:02 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
what do you do that blows the fuse?
Old Dec 8, 2006 | 07:24 PM
91Z28's Avatar
Car: 91' Z28
just pull the headlight **** to the first positon IE parking lights, Oh and ive replaced the headlight switch too....
Old Dec 8, 2006 | 07:30 PM
johnnyboy's Avatar
did it do this before or after you replaced the switch?
it sounds to me like you have a short somewhere, but you should check your grounds, there should be a ground in the hatch area somewhere, i'm not exactly sure where though.
or you might just have the wrong amperage fuse.
Old Dec 9, 2006 | 01:45 AM
91Z28's Avatar
Car: 91' Z28
This all hapened before i swapped out the switch about the time a swapped out my t-5, im using the correct amp fuse, i swapped the switch because i thought it was the problem, and after testing all the lights im convinced it's a short, where do these wires run inside the car ?
Old Dec 9, 2006 | 09:12 PM
johnnyboy's Avatar
the connections for the lights run along the back behind the lenses and then into the car on the driver's side and run behind the plastics and then along the floor on the driver's side.
Old Dec 10, 2006 | 03:23 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
i had this happen on one of my cars.It turned out to be the wiring that runs under the seats,shorting out.It'll be a pain to take the seats out and lift the carpet but well worth a look
PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Fanatic1074
Oct 2, 2015 03:47 PM
