TPI to Carb: Terminating Wires
Old Jan 6, 2007 | 04:42 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Just curious, can you cut out all the connections that you do not use anymore, such as the wiring going to the fuel injectors and smog equiptment? If so, what would be the proper way to do this? I wanted to leave the majority of the harness there and just cut off excess because I wasnt sure what could go and what could stay.
Old Jan 7, 2007 | 12:34 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Not sure what you have done and if you'd want to retain any function of the ECM at all, like TCC lockup. But you have probably removed/ disabled the ECM and the CEL, and if so of course you could just cut the unused wires, there shouldn't be any power there anymore.
If it were me, I don't like to hack up original wiring, so unless removing the entire ECM harness I'd just fold back the unused connectors and tape them to the harness. Factory does this.
Caspar
Jun 19, 2016 11:19 PM
Jae992
Aug 27, 2015 09:07 AM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
Sanjay
Aug 12, 2015 03:41 PM
