Running Lights wont work!
Old Jan 12, 2007 | 02:08 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
The running lights on my 85 Trans AM just stoped working at first I thought it was the switch because if I set it like half on kind of they would come back on (even that stoped working after a few times) but I replaced the switch and checked the fuse and all seems well but they still dont work. Now when I say running lights I mean all my running lights and my interior lights (the ones that come on with the running lights) Anywho I dont know what I should do or what wires I should be hunting down and I was hopping there was some easy fix or maybe a common problem. My head lights (high and low) work just fine and my blinkers work so I dont know if theres a short some where but I just wanted to see if someone could help.
Old Jan 14, 2007 | 10:54 PM
Car: Camaro
Engine: 5.slow
Anybody? Please I really got to get this thing fixed and I dont know where to start.
Old Jan 15, 2007 | 01:58 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
check the plug that goes on the back of the switch somtimes heat builds up and melts the plug so you dont get a good contact has to be something like that because the hole curcuit is down from what you say
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
