Temp Gauge gone crazy!!
Old Jan 14, 2007 | 08:35 AM
Mitre#136's Avatar
Car: 88 Pontiac Trans Am
Engine: 5.0L
Transmission: 4spd auto model unknown
Greetings GM gurus, the problem is, when the car is in idle (idles rough by the way, i'm still working on that) the temp gauge is fine, if i rev the engine, still fine, but once the car is in drive and accelerating, the temp gauge just climbs and climbs and makes it look like the car has overheated, but if you take your foot off the accelerator, the gauge returns to the actual temperature of the engine....is the temp sending unit grounded, ungrounded or just possesed? any help appreciated.
MITRE#136
Old Jan 14, 2007 | 09:23 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Sender provides a variable ground to the guage. It's located on the driver's side head and has a single wire connector. Make sure the connection's tight and the wire insulation is not melted or burned through and grounding somewhere under engine torque or movement. Grounding the wire sends a 'full hot' signal to the guage.
Old Jan 14, 2007 | 09:27 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Mine did the same thing and all it was, was that the gauge was loose in the housing. I removed the plastic covers and repositioned the gauge back in the cluster and replaced one of the missing screws. Everything was great after that.
Old Jan 18, 2007 | 07:59 AM
Mitre#136's Avatar
Engine: 5.0L
Thank you, i will be sure to check both in the engine side and in the interior, i'll be working on both sides during the weekend.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
wisemanz28
Sep 20, 2015 01:26 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
